Finally ... Successful Install of 22H2 Upgrade on W11 Desktop
w1smc
w1smc Member ✭✭
edited December 2022 in SmartSDR for Windows
I now have SSDR 3.3.33 running on W10 & W11 desktops & W11 on a Surface Pro all at WINVER 22H2 ...
I had issues with the 22H2 upgrade on the W11 desktop ... it failed 2 times with a BSOD (Portcls.sys Page Fault) before I finally got through a successful upgrade late yesterday.
I had to jump through the following hoops to successfully complete the upgrade to 22H2:
(1) I followed the "Complete Uninstall of SmartSDR instructions)" and uninstalled ==> SSDR 3.2.39, 3.3.29, 3.3.32, & 3.3.33
(2) Then I uninstalled the software for AG, PGXL, TGXL and FRStack (pobably didn't need to but did anyway)
(3) In a CMD window I ran:
DISM /Online /Cleanup-Image /RestoreHealth
sfc /scannow
(4) Then I stopped the Windows Update Service and deleted ALL of the files & folders in C:\Windows\SoftwareDistribution\Download
(5) Then I (re)started the Windows Update Service
** I did NOT disable my antivirus software (I forgot)
I rebooted the W11 desktop and then ran the update of the 22H2 upgrade w/o issue.
  • Val  DM1TX
    Val DM1TX Member ✭✭
    Hi Steve,
    Thanks for detailed information. Is good to know. However I run already SSDR v3.3.33 /22H2 on a W11 Pro system without any of the above issues. It is probably not affecting everybody. It is but true that at some point i had too this portcls.sys fault but after reboot it did not come back. I wonder if anybody else face this problem.
    MXMAS and 73
  • Al K0VM
    Al K0VM Member ✭✭✭
    It is not uncommon to have the portcls.sys BSOD after a fresh install of DAX ( included in SSDR install ) or a MAJOR windows update.
    Usually it does not reappear after rebooting.
    AL, K0VM
