What kind of license? Extended TX
In order to achieve transmit out of the amateur bands, you require the Extended Transmit Board for the FLEX-6400 or FLEX-6600 and a software key, which there is no charge for.
In order to get the Key, you need to open a support ticket and provide Government documentation from your country that allows you to transmit out of the amateur radio band.
-1
Thank you but the problem is to get a license to be on MARS is you need a radio that can TX on MARS frequencies hard to get if you won’t MARS mod a radio without said license.0
1.2.1.3. FCC License Class.
Applicants and/or current members must hold a valid amateur radio operator's license issued by the Federal Communications Commission (FCC).
4
1.2.1.4. Station Requirements.
1.2.1.4. 1. Applicants and/or current members must have an operational HF radio station prior to acceptance into the AFMARS program.
1.2.1.4.2. HF stations must be capable of operating on MARS frequencies, assigned by Region AFMARS officials.
1.2.1.4.3. New HF stations must have the capability of operating voice and digital modes specified by HQ USAF MARS. Digital mode is defined as any computer-generated signal other than continuous wave (CW).
1.2.1.4.4. Unless specifically exempted from this requirement, all H radio equipment must have a frequency stability and tolerance of +/- 20 Hz as set by the NTIA.0 -
So buy a 6500 or 6600. Then you have a radio capable. It is capable but inhibited until you show proof of license. Once you do that we can sell you the extended TX module and send the turf file for your specific radio to unlock the MARS/SHARES bands.
Simple enough.
Oh and as a reminder, even with extended TX enabled, the radio will not operate on 11 meters.
It’s more the point 5k radio and the company tells you what you can or can’t do to but FCC says I can but it my responsibility to be legal. You must be able to TX on MARS frequencies prior to getting your membership into AFMARS you do have to participate in nets prior to getting your membership. I don’t care about 11 meters but It can there is a couple C.B. pages all about how to mode Flex radios and they do have file moded for 11 meters. So I guess I’ll be not buying a Flex Radio sorry to be a pain 73.0
It does not say “Must be able”.
It says Must be capable.
The Flex 6400, 6500, 6600, and 6700 are all capable. To be FCC type certified we must sell the radio with transmit restricted to amateur bands only. Just like the YaeKenCom radios out of the box are restricted. They do not transmit on MARS or SHARES as sold.
Hi, we do hear your request. FlexRadio has taken the path we have as a part of the business model.
We have many many other customers who have purchased FlexRadios for MARs use without issue. A surprisingly large number actually.
If you change your mind, we are here to help you out.
I think the older 5000, 3000, 1500, and 6000 series (6300, 6500, or 6700) all just need a TURF file which FLEX will send you to run once on the Radio, at least this is how it used to be and I have my 6700 setup for MARS now and is what I did to for both my old Flex5K and the 6700 extend TX, My Friend also set up his newer 6700 with the TURF file last year.
Well, here's two for you. Until we sold our "Chris Craft" I had a Marine License.... I also have a Commercial General Radio Telephone that allows me to work on gear and have had that since 1974 and put myself thru college in various 2 way shops, etc. With the Shipboard License I could run up to 150W out on the HF Marine bands... With the General Radiotelephone and the Shipboard license, I can run up to 3KW output on the marine band. Is there a turf file that will make that work with my 6500? (Part TWO, Back in the day when I was still flying, I was a CAPTAIN in CAP and also was In AF Mars) giggle
Erika DD
No “First Phone”? No Ship Radar Endorsement?
It's really no big deal.
Submit you application to the branch of MARS you wish to join. Order the radio with the extended transmit board installed and if your MARS Operating Authorization comes prior to receiving the radio, copy FLEX and they will ship you the radio already activated.
If not, you can activate by filing a support ticket.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
