Smart SDR Mapping with shuttle pro v2 ,so you can tx radio and other controlson smart sdr
Rob,
SmartSDR does not have keyboard input shortcuts, which prevents directly using the ShuttlePro with SSDR. However FRStacks interfaces with the radio and does have a means of taking keyboard & ShuttlePro generated key inputs. The buttons work but I have not been able to achieve satisfactory knob control.
see http://www.mkcmsoftware.com/Flex/Index
AL, K0VM
This is an old thread, but thought I would add to it anyway.
I purchased a Contour Designs Shuttle Pro V2 and, using FRStacks, have it working very well with my Flex-6300.
Commands include a VFO knob (up going when turned CW and down going CCW) , a shuttle jog wheel that also moves the VFO Up/DN at accelerating rates depending upon amount of jog wheel roration (like an old FT-1000 MP jog wheel).
Other controls I've added include filter width (wider or narrower), volume u/d, mute speaker, binaural audio, mono audio, mode buttons for LSB,USB,CW,AM, tune, ANF, AGC, split and lock. This is a work in process so don't know if I'll stick with these or change them. All commands are easily changeable.
A helpful hint - when assigning keys in FR Stacks key editor, use "Alt + Ctrl + A through Z" as these keys are not used as Windows shortcuts and won't mess up any existing programs.
Contact me if you have questions. I'm good in QRZ.
Darryl
K0GV
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
