Visible strenght own audio in waterfall
When looking on my own audio signal in the waterfall it looks different when comparing 80m vs 20m. On 80m its so dark and seems like i'm not filling the set TX bandwidth. But in the band scope it looks ok. Also the sent signal seems to be OK according to reports.
On 20m it looks like as expected. I use same settings on Comp, mic gain and TX eq.
If your asking about the width of the TX signal--- Do you have the same TX filter settings of both bands ( They may be different for LSB vs USB and are not the same as the RX bandwidth settings. ) TX filter is not displayed in the PA.
If you asking about the intensity to WF during tansmit, you need to know that the PA/WF display during transmit is the result of fortuitus coupling between the TX signal and the RX ADC. The coupling is less at lower bands. Less signal is coupled on 80m vs 20m.
AL, K0VM
Thanks for reply and asking for clarification. Not the width, but the intensity in the visual representation of the sent audio/signal
Viewing your transmit signal on your transmitting slice is not truly represent your real transmit signal. If you can view it on a different RX and different antenna/dummy load/small coil of wire it will be more representative.
Also you don't show the dbm scale as specs define valid suppression levels. Your other sideband is 5 graduations down but how many dbm per graduation?
A little off topic, but the TX bandwidth upper cutoff is 2950, a good choice for most ssb work. However the TX eq is showing significant boost at 4K and 8k. These two settings conflict. The tx eq boost is being eliminated by the tx bandwidth filter. Not sure of the impact of this in the flex, but in the analog world, this results in distortion products in the transmitted signal.
Stan VA7NF: Tnx. I understand its not a true representation, but the difference was so big. Attached 3 new screenshots. I boosted gain in display, but barely visible in waterfall. I tried lowering MIC gain to 85, and also without comp, but then its all black on the high tones. Its only in waterfall, real sent signal looks ok on band scope and on air.
Tnx John KB4DU for pointing out the cut off. I use to have on 3200 when doing boost on 4/8K.
Your output power setting will have an effect on the brightness of the waterfall. In the example below I make three identical test transmissions at different power levels. 100W - 10W - 100W
73 Martin
That is to be expected,.. The color in the waterfall is dependent on the strength of the signal..
100W should be stronger than than 10W
AL, K0VM
Hi Al,
Yes, that was my point. In the screenshots we can see that he has the TX power reduced leading to a dimmer waterfall.
73 Martin
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 965 Third-Party Software
