Network Diagnostics statuswindow
Anyone now how to restore/reset the Network Diagnostics window size?
The window is capped so i'm missing the bottom. Happened after playing with change of resolution and scaling in Windows display settings Currently running 4K screen with 150% zoom in the display settings. Tried setting down to 100%, and change resolution back and forth, but the Network Diagnostics is still capped.
Of course tried dragging the corners.
//LA4XLA Reidar
Reidar,
I wonder if you have a problem with a wrong Font. I have much smaller type on my window.
73 Martin - G4ENZ
Good shot. You are on to something. Installed DidactGothic.ttf and napoliserial-xlight-regular.ttf which i saw was reported as need to fix a font issue on the frequence on the slice for some users.
The window changed a bit. now it looks like
This seems to be resolved. I switched to another physical monitor (not 4K) and its now displaying OK
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
