Very distorted recorded playback audio
N8SDR
When playing back recorded audio it is extremely distorted, noticed this with a couple other users as well, on both the M models when running SmartSDR or from Radio, and on the Non-M models.
On both newest releases of SmartSDR the 2.9.X and 3. containing the SD card patch. While it does not seem to be as distorted and broken sounding when done from the radio as compared to when done from SmartSDR it is awfully bad.
Reboots of both computer and or radio do not resolve the problem, and if your listening locally it sounds fine, but over the air playback is extremely poor.
Nothing like when has been recorded. Uninstalling and re installing DAX driver’s dose not resolve issue either.
I’ve had a few people have success by resetting the persistence database. Follow these steps exactly. https://helpdesk.flexradio.com/hc/en-us/articles/200831185-How-to-Reset-the-Persistence-Database-for-a-FLEX-6000 Dave wo2x0
I had this problem and found that DAX was turned on by autosave and when switched off the playback was OK.
In a more recent case I had audio distortion on playback and complete power down and radio power on reset solved the problem.
I also notice VOX only responds to playback of others I record, but not to local record. If I record myself and someone on the radio and then playback the conversation, with VOX enabled, only the other persons voice will be transmitted.0 -
Flex-6400, and Smart SDR 3.3.33 and other previous ones the problem is the same.
When playing back recorded audio it is extremely distorted. The transmission volume is too high.
On other computers the same happens, even the software installed for the 1st time.
I already opened a ticket1 -
DuDu, did you ever get your problem fixed?
- 391 Community Topics
- 665 The Flea Market
- 168 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
