Spectralissime, the Spectrum Analyzer
I just saw an interesting video on a program called Spectralissime, the Spectrum Analyzer. The program is developed by VB-Audio. This is like a Spectrum Analyzer for your audio. And not only that but you would be able to tell or show someone if they asked you "How Do I Sound"?
Spetralissime is a standalone Spectrum Analyzer application based on high precision band pass filter bank, more adapted to the human audition. Spectralissime gives a more consistent spectrum analysis and allows better understanding of any audio phenomena thanks to its constant precision, from 20 Hz to 20 kHz.
Here are the Specifications.
SPECIFICATIONS
Application Type:
Audio Digital Measure Tool Application
Compatibility:
Windows XP, VISTA, WIN7, WIN8, WIN8.1, WIN10 (32 / 64 bits)
PC Configuration:
Min: Celeron / Duo Core 1.8 GHz - 512 MB RAM - Disk < 100 MB
Audio Engine Capabilities:
44.1, 48, 88.2 or 96 kHz DSP Processing
Monitoring Output:
WDM, KS, MME, ASIO (32 kHz to 96 kHz) - 1 to 8 channelsPhysical Inputs:WDM, KS, MME, ASIO (44.1 kHz to 96 kHz) - mono or stereo.Virtual Input:
-none-VBAN Input:
VBAN Stream (44.1 kHz to 96 kHz)
M.I.D.I. Implementation (remoting):
-none-
Bands Number:60, 120, 240 bands (FAST or RTA).Measure Number:
Single analysis possibly coming from stereo signal (A, B, A+B, A-B).Timing:10 to 1000ms (including standard SLOW, FAST, IMPULSE).
Weighting:
A, Z(Flat).
Level Scale:6dB,10dB and Isophonic scale(140 dB dynamic).Frequency Scale:
Decade (x10), Octave (x2) and Music (20Hz to 20 kHz).Display options:Max, Average, PEAK, RMS, Peak detector (Bubble).Preset File:
XML file.
Has anyone out there tried this with the Flexradio? This was demonstrated on the Expert SDR.
Mark Griffin, KB3Z
Unfortunately, the frequency scale is only logarithmic (Decade and Octave), not very useful for CW or even SSB in my opinion.
73, Max
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
