DIGU reverts to USB, no extra programs
A while ago Glenn Depp asked about his DIGU setting reverting to USB (https://community.flexradio.com/discussion/8008837/ft8-digu-instantly-reverting-to-usb-and-no-rf-output); the answer seemed to be that he was using an additional program.
We are having the same problem in Windows SmartSDR 3.3.33: DIGU reverts to USB immediately on transmit. We are using only SmartSDR, CAT, DAX, and WSJT-X. We are using AC Logger as well, but that integrates with WSJT-X, not SSDR.
I (think I) know that the only difference is removing signal processing which I can also do by manually turning off PROC and TX/RX equalization, but I'm sure that what I'm seeing is not happening to most of you. Thanks for any pointers.
-Al WA1TYB
I think you should show us a picture of WSJTx radio tab. It might be this is the software that is manipulating the mode in SSDR. For example if mode is not set to None or if you are connecting it by some other means other than Flex 6xxx/ Network Sever..... we need some info on which to give a reasonable supposition as to the cause.
Bingo! Thanks, Erik. Mode was set to USB in the WSJT-X Radio settings dialog.
-Al WA1TYB
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
