Will the FTDI CH232HD work with the USB ports on a 6600M
Gary J
I would like to use CH232HD cables with my 6600M. I just wanted to see if they are compatible.
Best Answers
If it is an original FTDI chipset, you should be fine.
Thanks Mike!0
Mike Ill let you know they work out. Advantage is they are 1.8m long.0
Mike,just to let you know the cables are recognized by the 6600M.
I am using an AmazonBasic 7 port USB hub into the 6600. FDTI cable plugs into the hub.
I sourced the cables rom Mouser. Their part number is
895-C232HD-DDHSP-0
https://www.mouser.com/ProductDetail/895-C232HD-DDHSP-02
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
