Network Diagnostics statuswindow
Anyone now how to restore/reset the Network Diagnostics window size?
The window is capped so i'm missing the bottom. Happened after playing with change of resolution and scaling in Windows display settings Currently running 4K screen with 150% zoom in the display settings. Tried setting down to 100%, and change resolution back and forth, but the Network Diagnostics is still capped.
Of course tried dragging the corners.
//LA4XLA Reidar
Reidar,
I wonder if you have a problem with a wrong Font. I have much smaller type on my window.
73 Martin - G4ENZ
Good shot. You are on to something. Installed DidactGothic.ttf and napoliserial-xlight-regular.ttf which i saw was reported as need to fix a font issue on the frequence on the slice for some users.
The window changed a bit. now it looks like
This seems to be resolved. I switched to another physical monitor (not 4K) and its now displaying OK
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
