Do any of you also have a SPLIT problem since V3.3.29?
The error shows up as follows: ...The TRX works normally - but when activating the split function there is no output at the TX-VFO! Only renewed switching off of the split function with then short TX activation brings remedy and only then SPLIT (RX/TX on separate VFOs) works normally again - with a frequency / band change the game begins very much to my joy in the pile-up from new...
Has anyone of you also observed this behavior and if so, is there a "work-around" for it?
Oh yes, with the "VOX>Split-Problem" has this apparently not directly to do, since I never use VOX...
73 Hel, OE8TTR
Hel, I have the same issue running 3.3.33 remote on a 6400.
Hi Massimo, thanks for your experience - actually proves that this error is not hardware but software related! Let's see if anyone else reports with this buggy SPLIT function, because it seems that this will eventually be added to the BUG list and possibly corrected in an update, if several are affected by it...
73 de Hel, OE8TTR0 -
Yes, and so does a good freind of mine. We both have Flex 6400M's and discovered the issue last week trying to work the same DXpedition. Should we all put in Help desk requests?
Pete K1OYQ
Same problem here with 3.3.33 and 3.3.32 , VOX will not stay in very long must use PTT This is the first time I've used a PTT since 1976 . Then to do split for SSB DX , I have no transmit . To get it working I switch thru all the modes back to SSB and it will transmit . All the time it takes to do this the pileup is growing . All I hear FRS say is they know of the issue and are working on it . Really ?
Ed N5DG
No problem with Splits on CW and SSB this week running 3.2.39 on my 6600. I have been using that mode heavily working all the DXpeditions. Guess I will hold off upgrading!
Bill, NE1B
Flex Radio Systems GET YOUR ACT TOGETHER PLEASE!!! Great radio, but it need your attention now.
Pete K1OYQ
Same problem here with 3.3.33. Regenerating the pre split slice works also.
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 956 Maestro
- 57 FlexControl
- 931 Genius Products
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
