FRStack's SteppIR/SDA-100 not tracking frequency
I'm running a 6500, SteppIR SDA 100 with FRStack. I have the SDA 100 connected to FRStack, all "buttons" on FRS's SteppIR window DO work, but Antenna Frequency does not follow the Slice Frequency whether I select Autotrack or not.
SDA 100 "Transceiver Setup" is set to Kenwood, 9600 and I'm using the Data Out port. Windows 10 Device Manager shows my COM port also at 9600.
FRS Stack - "Radio" is connected with menu options selected for "Follow Radio Active Slice" and "Active Slice Enable TX". I have functional band stacking. My SPE amp is connected and all "buttons" work, but for some reason, the SDA 100 won't follow the frequency.
Seems like it's something simple I may be missing?
Mike KF9AF
You did not mention how you have the SteppIR Options set up for "Antenna Type" and for "Manual Frequency Synch".
If you want to control the SDA100 frequency from FRStack, be sure to select the "no CAT" option for your antenna type. The "CAT" option, is used when the transceiver is directly connected to the upper DB9 of the SDA100.
If you want, or not to control the SteppIR Antenna from moving with a VFO freque3ncy change, select the check box for "Manual Frequency Synch.
Alan. WA9WUD
Alan,
You specifically noted the one setting that made the SDA 100 track frequency. I had "Beam using CAT" selected. Changed that to "Beam no CAT" and it is now tracking.
This Community is AWESOME!
Thank you!
Mike KF9AF
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
