Duplicate Default Transmit Profile
Some how I duplicated the Default Transmit Profile. How do I delete one of them?
    Hi Marty, Assuming that you are running SmartSDR, go to Profiles, Profile Manager... Highlight the profile to delete and click the Delete button.
  • martyf
    martyf Member
    [{"insert":"I have 2 Transmit profiles named Default. If I try to delete either one, a warning pops up and states that it cannot delete Default,\n"}]
    Oh, I see. In that case, I would export your profiles. Uncheck one of the default profiles so that you only export one of them. Next, do a factory reset, then re-import your profiles. If you still have a duplicate, you would be best off submitting a help desk ticket.
  • martyf
    martyf Member
    Yes that worked for me. Thank you
    Marty/W5MF
