PGXL and TGXL mode issue
Kaos
Just got my 6600, PGXL, and new TGXL all hooked up. Had to do a factory reset to get TGXL to work correctly with PGXL. Now though when I use DIGU mode I don't get any output. 6600 and PGXL show ptt is working but not output. When I go to CW all seems to work correctly. Am running to Yagi tribander on 20,15, and 10. Any hints? My next step is to do a factory reset on PGXL.
Kaos
You say no RF out when you use DIGU mode. So...I assume you are using a digital input for modulation. In that case, make sure your TX DAX on on.
Alan. WA9WUD
My first question would be to ask if, when in DIGU, that the Radio Panel’s DAX light (next to the PROC button control) is blue and that the corresponding SmartSDR DAX TX indicator light is also blue. Both have to be on for audio to flow from your digital application to the radio transmitter.
And, of course, that your application’s sound setting are set to the correct DAX TX and RX audio selections.
Thanks guys DAX was on so after factory reset on PGXL I did a reboot on all software items SDR, AClog, WSJT and troubles went away. Poor trouble shooting on my part as this should have been in my process.0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
