New CW operator question
I have a Flex 6400 and I am just starting my CW explorations. I have been reading the forums and I have drawn some conclusions I would like to run past the more experienced operators.
For learning and rag-chewing with CW, using the built-in keyer and CWX should be fine. If I need easy macro buttons, I can use CWX. If I get serious about contesting with CW, I can look at using an external keyer. Am I reading things correctly? Remember that for now, I am a slow speed operator.
Thank you for the time and comments,
Brent, VA7BNB
Hi Brent, An external keyer does not bring much advantage over the internal keyer. Most contesters use a logging program that has CW macro capability like N1MM or N3JFP's AClog.
As you gain experience and start participating in contests, you will see where your preferences lie. These preferences will take you to the solution that is optimal for you. If you constantly wish that you had external buttons to push for messages, then an external keyer might be the right thing for you.
On the other hand, if automatically sending the other station's call sign is important, then a logger with that capability will be the way to go.
Thanks Len
You have confirmed my readings. I was getting too deep, too fast.
Brent, VA7BNB
Welcome to Flex Brent, from a long time BC CW contester and 6700 owner.
As Len said, pick up a copy of N1MM+ for both contesting and for just setting the message buttons.
No need for an external keyer, stick with the one built in. My personal choice is to use a single paddle key rather than iambic key as you will find it creates less "surplus" Morse elements and is more comfortable once you reach 25WPM+ which is the norm for most contests.
Thanks Stan.
I am using a Vibroplex single lever paddle. I found after my **** I got too many "surplus" dits and dahs.
...Brent... VA7BN
Oops. The **** should be ****. Dunno what happened.
Hi Brent, the bad word filter on this forum is a bit overboard... For example, a helical fastening device (i.e. a ****) will be flagged.
Most of us put dots between the letters of words that get unnecessarily censored. In my example above, the word is s.c.r.e.w.
Once you post, you have an hour to edit it. If you see the dreaded asterisks, you can go back in and choose a different word or use the dot trick.
Another mention, due to much latency in the windows audio stack, and especially for quick turn-around contesting, plug your headphones, key, (even a mic for those rare voice contacts) directly into the flex. That bypasses the latency and you will likely respond to calls 1/2 second faster.
Also you will hear the N1MM originated CW plus your own keying
A big Thank you to Len and Stan for your answers and guidance.
Stan, the word that got **** out was s.t.r.o.k.e.. I have always plugged the Vibroplex, powered speakers and headphones directly to the 6400. I was aware of the latency, but to my mind, plugging directly into the Flex was the best way to go.
...Brent... VA7BNB
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
