audio clicks, dropouts when using mac smartsdr, wsjt-x, fldigi.. on older mac
howdy..
older 2014 25” intel imac with smartsdr, flex 6600, rogue amoeba. when transmitting if i click another window the transmit audio will click or briefly dropout. i do have node red running on a pi-4 watching a kpa-500, swr, antenna switch, and such.
big sur 11.7.1. smartsdr and wsjt-x are current.
time to upgrade the mac hardware, or any ideas on where i can look to solve this?
thanks!
ken, ns7v
Hi Ken - I mispoke earlier, was not near the Mac. I have 64 Gbytes (that really is GBytes, not Mbytes) of memory in my MacMini. The CPU is a 3.2 GHz 6-Core Intel Core i7 (2018).
Memory in the machine makes a huge difference if you run multiple apps. I can run JS8Call plus xDax / xCat and Loopback, plus EITHER SSDR Mac for WSJT-X, or Parallels with SSDR Win plus VarAC or WinLink with absolutely no dropouts or stuttering audio. I rarely run phone, so don't know how SSB tx would work, but when I listen to phone, the audio is smooth.
If Node Red is send TCP commands to radio, you will hear a click or pop. With the FlexRadio flow version 16_4 I send the TCP commands when the flow starts and then if clicking a button to send a command.
The other cause can be the MACBook is underpowered to handle running all the programs that you are running. WSJT-X will spike CPU usage at end of each cycle as it decodes. Try looking at performance metrics on the MAC to see what is going on.
I’m relatively new to MAC and haven’t got everything set up on the M1 CPU Mini yet.
Hi David,
Thanks for the reply. Disabling Node Red does not improve the problem. Adding an audio monitor to the Loopback pass-thru device, I don't hear any dropouts or clicks. Monitoring on a K3 at the same time--the clicks are there.
Using the built in FT8 client in the SmartSDR program--it all works fine with no clicking or dropouts. Might have to use that, though I'd rather use WSJT-X or similar.
When cpu use is low, the problem persists with WSJT-X and even tried JTDX...
I appreciate the suggestions!
Ken ns7v
Ken, you don’t specify how much memory you have in the iMac. In general, the more recent the OS, the more memory it needs. I’m still running MacOS 10.15, and refuse to go to Big Sur for various reasons. I have a 2018 MacMini with 32 Gb of memory, and never have dropout problems. Memory is important to prevent swapping in and out to/from disk.
Dave’s advice to look at performance is a good idea - look at CPU, memory and disk.
Hi Ted,
Thanks! 32 meg and low CPU use. I have to admit that this particular macnine is 2014... i have later macs used for other things, and i may have to pull one over to the shack and try one.
Good to know that this will work given the right setup. I'll keep plugging.
73!
ken ns7v
i appreciate the comments, ted. our systems are similar—parallels, winlink, wsjtx, etc.. mine is just a lot older. i’ll upgrade the hardware and report back.
also, thanks dave. nice to get good help here!
ken ns7v
You will find there are very good people willing to help on the Community.
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 174 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 881 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 735 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
