No TX in Panadapter B
Hi everyone!
I need help, I am configuring my Flex 6600 in SO2R for the CQWW SSB but I have a problem. It is using my station in PR via remote, I am in TX. I have 2 panadapters open (A and B) but I transmit using the headset on A and it transmits fine, then with the mouse I give TX to panadapter B and it does not transmit. I do the same thing but in CW mode using CWX and it transmits in both (A and B) Having this problem I can't finish configuring N1MM since to make the changes between Panadapter A and B I use / and it makes the changes but it doesn't transmit in B. I did a test using the N1MM macros and making the change with / and it transmits well in both panadapters but not with the headset. The headset is connected via USB. Any help would be appreciated.
Al WP3C
I had a similar problem getting mine working. Check N1MM+ configuration to:
- make sure that you have selected 'PTT via Radio Command SSB Mode' for both ports
- make sure that you have Radio Nr 1 set in one port and Radio Nr 2 set in the other1 -
- make sure that you have selected "PTT via Radio Command SSB Mode" for both ports
Strangely, i had the same problem a few days ago without using anything like N1MM at that time. Just remote with audio from PC. I thought i must have mixed things up and wanted to try direct at the remote site first .
I wanted to do a short qso on Slice B while watching a net on Slice A . Did not send out anything..but keyed to TX .
Maybe some regrression after updates ?
Harry
Hi Harry
You would just move your TX Focus. Did you see any Mic Level Audio?
Did your Mic input change to some other input?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
