Flex6000M, JTDX, JTAlert (Blue)
Up to now I have been using WSJT-X with JTAlert (red) with no problems. I have heard that JTDX will dig deeper when decoding so I want to switch over to that. I had been using SliceMaster 6K with WSJT-X and JTAlert (red) and using HRD as the radio control. This setup is not working with JTDX and JTAlert (blue).
  • nt9e
    nt9e Member ✭✭
    If I use use OmniRig it works but it should work with the same setup I had before.
    To get JTDX to work with SliceMaster, you will need to edit the SliceMaster .ini file.
