sound monitor
edited October 2022 in Third-Party Software
Hello everyone ,
I have a sound problem, the flex going back to my monitor (4 k TV), exple: in ft8, I have the sound "TX" and "RX", to delete I have to cut the sound of " dax audio rx 1 "and" dax micro audio ",
my question, how can i delete, the path from the two DAX to the monitor "philips ftv, without deleting, the other paths
Flex 6700 win 11
ON5PO, Janny
Welcome!
  • Member ✭✭✭✭
    Janny
    Check that your "Monitor" is off.
    Alan. WA9WUD
  • Member ✭✭
    Hello, Allan,
    Yes is "off"
    thank you for your reply,
    73, janny
  • Member ✭✭
    Hi there ,
    I come back to my problem, which has evolved in the wrong direction, since my first request.
    the sound, from the flex 6700 comes out through the rear speakers of the flex and through the speakers of the screen, as I wrote the first time, I managed to remove the input to the screen now impossible, I have to to mute the screen sound, only if I want to open skype for example, the two sounds mix.
    Who could help me solve my problem, before disturbing flex with a ticket
    thanks in advance
    73 on5po, Janny
  • Member ✭✭
    solution found, the fact of configuring my spare wheel an ft991A, I recovered the sound ports, as originally.
    ON5PO, Janny
  • Member ✭✭
    the hope was short-lived, it came back as before always the two sounds at the same time
