Do I have a Problem with my RX
My problem
Just updated to V2.8.0 and now getting LOW RX signals not sure why ??
Equipment used
Flex 6300 to a LDG 1000ProII to a G5RV Full size Listening against a Yaesu FT2000 to a MFJ998 to a G5RV Full size Standard RX on the Flex 6300 and IPO just set to ON with the FT2000 so I thought the RX signal should be around the same on both Radio's but I'm getting about 3 to 4 S points different on the Flex 6300 lower so Flex 6300 showing S5 and the FT2000 showing S9
I've looked at the Video by Flex called Understanding FlexRadio's S-Meter readings and did the same test and MY flex 6300 is showing almost the same S reading as Mike VA3MW's Flex is showing so it's quite confusing is My Flex 6300 working as it should or is something wrong with it's RX ??
I've done a video showing what I'm getting from My Flex and also going through what Mikes doing in the Video also The first 6.05 min is the explanation of the above equipment and the rest is about what I'm experiencing so any help would be gratefully received.
https://www.youtube.com/watch?v=-jJHxQYDTsc
Rob
LZ2AOV
Hi Rob, you might want to swap antennas with your FT2000. That will help to see if you are having a problem with your Flex or if it is something in the antenna system (feedline, connectors, antenna). You might also move the feedline to the Ant 2 connector to verify that it is not the antenna relay or associated circuitry in the Flex.
HI Len
Just tried what you have suggested and the signal on ONLY Radio, No ATU, The lower G5RV seems to be about 1 S Point better than the Higher G5RV maybe it's just propagation for my Location, I'm just testing on 40m at the moment and the strongest signals are S9 from Turkey nothing over S9 but then again with my FT2000 the same station is S9+20 so around 3 S Points stronger it's head scratching but I'll keep checking thanks for the advice I'll try anything at the moment to see if I have a problem with my Flex or not.
73's
Rob
Hi Rob, it sounds like an issue with your 6300. I think that I would submit a help desk ticket.
Thanks Len I just open one
Just an update have checked things out with the Support Guy's at Flex and the out come is the 6300 will have to go in to Germany for repair so hopefully will get it sorted and back working in the shack as it has done for the last few years.
Thanks for the help Len and Flex Tech
Rob
73's
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
