I purchased Smart SDR on My IPhone but can’t get it on my IPad mini 2
Does anyone know the answer
HI
First, make sure you are using the same apple-id for both devices
and
Second, that you are on the latest ios for all your ios devies
but
i think ipad mini2 is stuck at ios 12.1 i and can not be able to updated to latest ios (ipad ios 15.7)
and
that may be your issue
Paul K3SF
[{"insert":"Good morning \nMy Apple ID is the same but the IPad is at the latest version for the Mini which is 12.5.6.\nDoes that mean I need a newer IPad?\n\nThank you for your response. I appreciate it.\nNick KY4Q\n"}]0
Hi
yes...
i have run into tha same issue here with ipad2
you will need a newer ipad that runs latest ipad ios...
apple will be releasing new ipads in Oct 2022....
as well asupdate to ipad ios v16
here is article that show what ios devices will suport io16 come late october 2022
https://www.wired.com/story/apple-iphone-ios-16-ipados-16-new-features/
i also have ipad pro with latest ipad ios and it runs iosssdr no problem
and
i had iphne12 that also ran iosssr
and
i just updated to iphone14 with great deal from verizon
hope this info helps
Paul K3SF
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
