SmartSDR V3.3.33 Successful upgrade
I just upgraded my 6400 from V3.3.32 to V3.3.33 without issue. The upgrade was quick and painless.
I had some hold-over DX spots that were unresponsive. I cleared all spots, closed SmartSDR and re-opened it and they were gone. All new spots seem to be working perfectly.
I will try a remote login using SmartLink later today. Since I did not have any of the issues affecting the 6300, 6500 and 6700 radios, I doubt that I will see any difference in my remote operation.
Worked like a charm. Easy load from 3.3.32. Completely functional. Would love to know what caused this. Jim KD1I
Me too works great!
Me too.
Update without issues.
Smartlink does work too.
I am running v3.3.32 on a 6400M. In reading the announcement for the v3.3.33 upgrade, the fixes are for other versions of the FlexRadio family and my 6400M wasn't mentioned.
So, is the upgrade actually recommend for the 6400M as well. For me it appears that this is one of those "if it isn't broke, don't fix it" scenarios. My radio works fine now.
Regards,
Dean W6DBJ
Similarly, my upgrade to 2.8.1 went completely uneventful. :-)
@Dean Jacobsen Flex says it's recommended for all. I'm running a 6600M. All went well.
Same here. I'm using a 6600M. I went ahead and did the update just in case there may be some undocumented improvements elsewhere in the firmware and SmartSDR.
I didn't experience any problems updating.
Upgrade went well on my 6400 but Smartlink still doesn't work. It was working prior to 3.3.32
Certain my port forwarding is correct as I have other things I access from the outside/internet and have no issues. On the Smartlink setup I've tried both "automatic" and "manual". Both don't pass the test. On my IoS client it does show port as -1
Updating without problems Maestro and Flex 6400 thank you Flex
Painless and quick upgrade for my Flex-6700 from v3.3.29 to v3.3.33, and so far everything seems to be working fine. Reference my Maestro(A), it took two tries to get my Maestro(A) to accept v3.3.33. The first upgrade attempt failed, but the second attempt was successful.
Thanks again to the Flex team!
Butch, KF4HR
from release notes:
Please refer to the SmartSDR v3 Changelog for a complete listing of changes in the\nSmartSDR v3.3.33 release.
Where to find the changelog?
73 Ulf, DL5AXX0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 937 Third-Party Software
