No Slice - Can't add 1
I've seen some startup issues ie no VOX. I've also had garbled TX and RX after rig has been on for a few hours. All in the last two days. Restart has cleared both issues. I'm not impressed with 3.3.32.
I have the thread indicating the same issues and have submitted a Help Desk Ticket, received a response and supplied info as requested. https://community.flexradio.com/discussion/8027134/windows-10-updated-today-lost-all-functionality#latest
I tried the downgrade step to 3.3.29 and had the same issue with no slice. So, I upgraded BACK to 3.3.32 and the upgrade never finished. My 6500 is now displaying "Timeout" and the power LED is flashing red in 3-flash increments.
Guess we'll have to wait and see what Flex comes up with. Right now, my 6500 is a brick.
Mike KF9AF
Tim is remoting into my system to collect some info. Update, Tim did log in and used some tools to collect a bunch of info from my 6500.
:'( why is this because mine is but not downgraded Go to version 3.3.29 Because I'm not sure how there should be a solution for this kind of incident. Why is it all on the same day, so many people? Is it because of the operating system or is it the software? i’m use flex 6700
de E23NEZ1 -
Hi
So far quick fix is to downgrade to 3.3.29 and it seems to be working on 6500
I did a downgrade and it worked again, but I turned off and on my 6300 and again the same problems, I updated to 3.3.32 and the same, it started to work, and after turning off and on again, the radio does not work. . •
Exact same issue here at WE7L since early this morning (also submitted ticket then) with my 6700 running V2.8.0 Very odd we all experienced this on same day. Good luck to the engineers & others working on this for us. TNX for work-around info, but think I'll wait see if there's another fix.0
Powered up my 6600M. No issues so far. Connected first from my Windows 11 pc, updated yesterday. Again, no issues. Just now connected with my Windows 7 pc and still no issues with SmartSDR. Currently running v3.32.32. It is odd that some have this problem with no Slice showing. And after downgrading and upgrading are back to normal operation.
Windows 11 did take an update last night to the DotNet runtime. At first I suspected that it was the source of the problems many are encountering. Now, I am not so sure.
I have the same problem. I tried the downgrade method and it looks like it corrupted my SIM card. getting the timeout error and the red light flashing. looks like I will have to submit a help desk ticket and most likely will be replacing the SIM card.
G. Morning, Trucker, the problem is seem to be with with the Flex 6300, 6500 and 6700, I haven´t got news with 6400 and 6600 radios.
Hello ,
this morning, when my 6700 started up, it reached 3/4 of the calibrating --> "timeout --> red lamp.
73 on5po,Janny
Norbert,
I removed the program from the PC, downloaded 2.8.0, still a problem, "--> OK+ and we "au flex, now ok
Hello on5op, like the song says "another brick in wall"... This is unaffordable, innumerable smartlink crashes, it is scary to update the equipment, cards that fail, little stability of the updates.
I also had to change the cpu and fpga fans of my 6300 due to lack of quality.
After one of the most notorious smartlink crashes, we installed a VPN so as not to depend on Smartlink, I was also criminalized for my comments, and for not having a vpn installed. I was lucky with the card, it had been changed at the technical service in Europe a year before, otherwise I would have been affected too.
Our radios are not exactly cheap to always be on the tightrope...
I had this "no slice" issue yesterday. Tried different things (radio reset, removed Windows 10 recent updates etc.) but nothing helped. Upgrading the software from v3.3.29 to v3.3.32 fixed the problem. Used my Flex 6700 with v3.3.32 in the CWT today and it worked with no problems.0
Hello Eric, thank you for copy and paste the post of mike everywhere, I take part on a telegram group, and the majoriti people of the group with flex 6300. 6500 and 6700 have our radios as a brick , we have share the post of Mike.
We hope get our radios back again, there are a lot of ham operators all over the world afeccted for that issue.
Thak you very much.
I just now experienced this problem today, for the first time. Release 3.3.32 was working fine for months.
I also upgraded my laptop to rel 3.3.32 today but it has the same issue.
SN 2915-5040-6500-4848 Release 3.3.32.8203 Sure hope the solution comes quickly. Jim KD1I
Quick & easy fix if you happen to be a bit lucky as I was. Was using a 6700, Win10, SDR version 3.3.29.7670. So no need to downgrade in order to upgrade back to latest version. If the version you are running precedes 3.3.32 you need only install the later version. My install was smooth and entirely automatic. My 3.3.32.8203 is running perfectly with all settings, profiles, etc., automatically installed.0
I just got the same problem....6700 no slices
Same problem here....6500 no slices
Same problem here downgraded to 29 and back to 32 and now I is working fine0
We can see some can recover their radios downgrading and upgrading the software, the majority we have our Flexradios as a brick, I did everithing I could, imposible.
In the same boat with everyone else was working fine yesterday, Flex 6500 running v2.8.0.
Turned the radio on this morning and have the same issues.
NC4AB
This is a really weird bug. I don’t understand how firmware that hasn't been touched can fail. And I haven’t seen any reports of the issue on 6400/6600, which is even more weird since the same software is installed as the failing radios. My 6400 still works properly.
Since it happened to a bunch of users on the same day, I suspect that a 3rd part (MS?) did a software update that uncovered a previously hidden bug in SSDR. At any rate, Flex has acknowledged there is a “software defect” and hopes to have a new release by the end of the week. It’s Thursday evening on the East Coast so we will see.
@John KB4DU I had this issue before it was widely reported on my 6600M. It wasn't permanent though. All I had to do was restart the rig. All was fine. It happened two or three times.
i have seen similar issue with my 6600m. The slice would appear but no control over it.. It appears as if no profile was loaded by the radio. So with the 6600m main screen i just loaded a profile and all was fine ..
no reset required for my setup
This seems to happen when i shutdown too quickly...not waiting long enough for orderly shutdown before removing power( aka turning off the power supply).
This happens whether i use ON/OFF button on the 6600m or if i use remote shutoff feature.
i need to be patient.. ;-)
Paul K3SF
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
