Getting MMTTY to TX in RTTY mode in SmartSDR
Andrew O'Brien
Member ✭✭✭
I can get MMTTY to transmit when using SmartSDR IF I set mode in SmartSDR to Digi-U or Digi-L BUT NOT if I set the mode in SmartSDR to RTTY. If I choose DigiU or DigiL instead, and use N1MM ... a click on the waterfall switches things back to RTTY mode and thus no transmit. I see instructional videos on the set up and they all show SmartSDR in RTTY mode. Any suggestions?
Andy K3UK
Thanks Len, Duh! I spend an hour fiddling around last night and was nowhere close to finding my obvious mistake.... the fact that DAX turns off when I got to RTTY mode. You saved me hours of more head scratching
Andy K3UK
Hi Andy, In MMTTY, go to Option, Setup, SoundCard tab and set as follows:
In SmartSDR, make sure that you have DAX on:
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
