Getting MMTTY to TX in RTTY mode in SmartSDR
I can get MMTTY to transmit when using SmartSDR IF I set mode in SmartSDR to Digi-U or Digi-L BUT NOT if I set the mode in SmartSDR to RTTY. If I choose DigiU or DigiL instead, and use N1MM ... a click on the waterfall switches things back to RTTY mode and thus no transmit. I see instructional videos on the set up and they all show SmartSDR in RTTY mode. Any suggestions?
Andy K3UK
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    Answer ✓
    Thanks Len, Duh! I spend an hour fiddling around last night and was nowhere close to finding my obvious mistake.... the fact that DAX turns off when I got to RTTY mode. You saved me hours of more head scratching
    Andy K3UK
    Hi Andy, In MMTTY, go to Option, Setup, SoundCard tab and set as follows:
    In SmartSDR, make sure that you have DAX on:
