Replacement for Omnirig? Is that even the problem?
I have used my 6600 with a Maestro now for several years using Omnirig, CAT and DAX and the following software:
Logging - Log4OM
Digital modes - WSJT-X & JTAlert, MMTTY
Contesting - N1MM+
Suddenly, a couple months ago, connectivity to the rig from the PC was lost. Initially I thought it was related to a network change I had made in the house, but I’ve moved away from that when the problem persisted after I returned to the,orig network config.
One symptom that bothers me is that when I ping the IP addresses the Maestro reports for the 6600 and the Maestro from the PC is the 6600 pings successfully but the Maestro’s IP never responds. Thats a head scratcher. Turning off Norton Security has no effect.
Regardless of the software I run with the rig, none can talk to the rig’s CAT controls. I’d like to try something that would replace the function of Omnirig to see if perhaps that helps. I’d you can provide a suggestion, I’d sure appreciate it. Nothing about this problem makes sense to me.
73, Duane AC5AA
Hi Duane... I am running the similar config on my 6500. I've found tho, that you have to use the 'old' version of OmniRig (v1.2.0). The newer 2.x version will not work with Log4OM.
Thanks, Don - I’ll try that tomorrow.
No worries.. If you need any assistance with config, etc. let me know!
1.2 is what I’ve been using - it is the currently downloadable one. I’ll spend more time on it this afternoon.
There is a 2.1 version available from a ham in Switzerland. That's the one that won't work with Log4OM.
I got my 1.2 version from here... DX Atlas: Amateur Radio software
BTW, with this older version, I've found that once you start it up, you must just leave it running -- don't hit the OK button at the bottom as this will shut it down.
1.2 is what I have been running. I found a statement on the Log4OM forum saying all needed to be run in administrator mode, but that didn’t help either. This is a real puzzler.
Nope.. I don't run mine in admin mode, but the computer is a 'single user' one, so I guess my account is an 'administrator' by default.
Here's a screen shot of my OmniRig settings:
... and here's what my SmartCAT screen looks like...
In v2.23.0.0 of Log4OM, under Settings/Hardware/CAT Engine, Cat Engine should be set to OmniRig and the Cat AutoStart should be selected.
Thanks, Don - Those are my settings. Here is a snapshot of them:
I believe these are the same settings that have worked for the last couple of years - I've done nothing to change any of them (that I'm aware of). Maybe you can spot something. Thanks again for taking the time to help.
Just noticed you have RTS=High while I have it Low - changed it's value - no improvement.
Only difference I see for now (it's late at night :-)) is that I'm running 38400 and you're running 56000 for baud rate. Maybe try that???
otherwise, things look pretty similar. And your SmartCAT is showing it 'sees' the Omnirig. Hmmmm
In Log40M, what does the Omnirig tab look like under CAT interface?
Again, no improvement. It looks like it is a problem with Omnirig since WSJT-X also fails similarly. Just to give something a try, I uninstalled Omnirig and then reinstalled. Again, no help. Argh. I believe if I go Slicemaster it won’t help running Log4OM, and HamLib appears to have its limitations too.
Hmmmm... I'm running out of ideas.
Are you able to run SmartSDR on the PC and see if Log4OM connects with OmniRig and the Flex?
Yes, makes no difference whether I run the Maestro or SmartSDR on the PC. Both run the radio fine but neither connects to Log4OM or to WSJT-X - that’s part of what is making me think it’s an Omnirig problem since it’s a common point. N1MM+ also fails to connect, but I haven’t looked at it yet since I’m trying to just get something to connect successfully. Thanks for hanging in there with me on this, Don.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
