FLEX 6500 DOESN'T PULL IP
i HAVE RESET RADIO BY HOLDING OK AND TURNING ON
RADIO SHOWS IN DAX WITH A 169.254.4.103 IP WHICH IS NOT IN RANGE OF MY NETWORK AND I CAN NOT ACCESS THE RADIO
THIS WAS FROM A ESTATE AND I'M NOT SURE WHAT STEPS NEXT
THANKS JACK WC4J
Hi Jack... What version of SmartSDR are you running? Is the MAC version? Is the radio directly wired to the computer/to the router?
I would suggest opening a Help Desk ticket. The Flex group are very good at addressing and fixing network issues.73
VER 3.0.27.131
WIRED TO A MANAGED SWITCH WITH A STATIC RSVP IN ROUTER
IVE GOT A TICKET IN I DID GET A IP AFTER POWER CYCLING SEVERAL TIMES AS A POST I FOUND SUGGESTED THOUGHT I'D ASK TO SEE IF ANYONE ELSE HAS HAD SIMILAR ISSUE0 -
Hmmmm... has this configuration worked before?
Reason I ask is that there have been reports before of problems with 'Switches' in the network not properly passing the required packets.
BTW, any reason for posting in all caps? :-)
sorry was doing RTTY on MARS i forge to switch caps
this is a radio I got from a estate i do not know its history so I have been shooting in the blind.
I seen the other posts thus why I cycled power a few times
my network is running a ubiquiti managed switch the model is not coming to mind
dhcp server is a untangle firewall box running on a supermicro 1U server i would expect the network gear is quick enough but i think the issues folks are having in the other posts are when there are multiple switches or wifi involved this is a 10g rated switch running 1g and 2.5g to devices0 -
OK, thanks for the update on the config. I'm no expert on wifi networks, so I'd still suggest submitting a Help Desk ticket to get the Flex folks involved. They have PLENTY of experience getting things to work on various networks!
You mentioned you are using a Managed switched.
Can you test with an unmanaged switch?
Is the router setup with DHCP to offer IP addresses? Is the address pool possibly already full?
The 169 address is a default address that a system generates when it has tried to get a DHCP address and it fails.
Have you tried any other devices on this router?
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
