Turn DAX on with Streamdeck?
Hi All
Am trying to find the REST command so I can ensure DAX is turned on every time when using RTTY. I have a command to set the DAX channel to 1 or 2 depending on what slice I am using but finding that DAX is not always enabled.
I usually find this when I go to TX and no diddles are generated.
I use a 6600M so this is done by pressing the MIC/SPEED button in to get the screen and then tap 'DAX' to turn on.
I use a streamdeck to change bands as then I know all the settings I want are correct - Band, Mode, TX Antenna, RX Antenna etc.
I'd like to add another line to ensure DAX also on too.
I looked at the API help and can only Find MODESETDAX but this seems to only apply to DIGL and not when mode = RTTY.
Has anyone managed to do this, if so how please?
Rich
Rich
Which DAX do you speak of, TX DAX or RX DAX?
In FRstack REST commands, TX DAX is in the "Radio Commands, on/off". RX DAX is in the Slice Commands, channel "1-8" or 0, "off".
Alan. WA9WUD
Hi
I have RX DAX working fine but can't get TX DAX working.
Like I said the command listed doesn't seem to toggle for RTTY, unless you have it working?
Rich
You don't favour the FRStack Hot Key method then? I simply call it from Stream Deck as part of a multi-action command, either ON if it is OFF or the reverse.
Calling it again will turn TX DAX on. The Hot Key combination is by your preference.
You could set up a mic/transmit/global profile combo for RTTY then call the global profile from Stream Deck.
I’ll check for the DAX TX command.
Hi Erik
Thanks for this, everything I have done has used REST commands so hadn't thought of hot keys.
I need to always turn it on though (or keep it on when already on), I will be assigning it to a multi action band change function I have set-up, I don't want to turn it off at all.
Rich
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
