Turn DAX on with Streamdeck?
Rich M5RIC
Rich M5RIC Member ✭✭✭
Hi All
Am trying to find the REST command so I can ensure DAX is turned on every time when using RTTY. I have a command to set the DAX channel to 1 or 2 depending on what slice I am using but finding that DAX is not always enabled.
I usually find this when I go to TX and no diddles are generated.
I use a 6600M so this is done by pressing the MIC/SPEED button in to get the screen and then tap 'DAX' to turn on.
I use a streamdeck to change bands as then I know all the settings I want are correct - Band, Mode, TX Antenna, RX Antenna etc.
I'd like to add another line to ensure DAX also on too.
I looked at the API help and can only Find MODESETDAX but this seems to only apply to DIGL and not when mode = RTTY.
Has anyone managed to do this, if so how please?
Rich
  • Alan
    Alan Member ✭✭✭✭
    Rich
    Which DAX do you speak of, TX DAX or RX DAX?
    In FRstack REST commands, TX DAX is in the "Radio Commands, on/off". RX DAX is in the Slice Commands, channel "1-8" or 0, "off".
    Alan. WA9WUD
  • Rich M5RIC
    Hi
    I have RX DAX working fine but can't get TX DAX working.
    Like I said the command listed doesn't seem to toggle for RTTY, unless you have it working?
    Rich
  • Erik Carling EI4KF
    edited September 2022
    You don't favour the FRStack Hot Key method then? I simply call it from Stream Deck as part of a multi-action command, either ON if it is OFF or the reverse.
    Calling it again will turn TX DAX on. The Hot Key combination is by your preference.
  • David Decoons, wo2x
    You could set up a mic/transmit/global profile combo for RTTY then call the global profile from Stream Deck.
    I’ll check for the DAX TX command.
  • Rich M5RIC
    Hi Erik
    Thanks for this, everything I have done has used REST commands so hadn't thought of hot keys.
    I need to always turn it on though (or keep it on when already on), I will be assigning it to a multi action band change function I have set-up, I don't want to turn it off at all.
    Rich
