Using the TGXL and PGXL with a Yaesu radio
So, I see in the manual I can use a straight DB9 to DB9 from the radio ....FTDX101MP......to the amplifier. But, now how do I provide that data to the TGXL? In other words, there is only one DB9 connector on the radio and amp, so how do I daisy chain the TGXL into the mix? Is there a way to somehow split the DB9 cable and have it feed both simultaneously?
Peter
You could bring Yaesu CAT into PC via the radio’s USB cable then use a program such as Virtual Serial Port Emulator (VSPE) to set up a serial port splitter then serial port bridle to two USB to serial cables, one for amp, one for tuner.
Hey Dave thanks great response. I already pull the data out of the radios's into the PC so your idea is pretty good. I have that program already but hadn't used it in a while. Thanks for that one.
Peter
No problem. Feel free to reach out if you need help.
Email me. I have a document I wrote quite a few yeats ago that covers what you want to do with VSPE.
My e-mail is good on QRZ.
73 Dave wo2x
Hi, were you able to get it to work?
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 14 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 899 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
