Flex Dynamic Range Degraded from Upgrade Software
Hi
I am not sure what the issue was as I can't connect this posting with a customer record and the helpdesk system is by far the best to follow up on this as it is a direct to engineering assuming we have collected all your operation info.
As for dynamic that data seems pretty dated as Mr Sherwood has not tested one of our radios in a long time. The 6700 was in last tested 2017 and the 6600 in 2018. A lot of software has been written and installed since then with many changes.
One key thing to remember is that radios such as an SDR with a front end ADC actually perform better and have better dynamic range with multiple signals in the pass band. The exact is opposite is true for a Superhet radio. When any radio is tested, it is with one signal in the RF passband. Yet that is nowhere close to real world testing.
The RMDR on the 6700 is 128db and arguable a much better test with an front end ADC.
The other thing to keep in mind is that testing of SuperHet radio and a Direct Sampling radio is not an exact science especially when it comes to real world performance. I don't think anyone has yet to publish the best test bench procedures for any direct sampling radio.
As long as there are radios that we use every day, there will be discussions of how the radio tested on a bench. :)
Hi Rob,
Sorry, don’t know your call.
I’ve been using my 6600M and working a lot of DX (except last few weeks which have been hectic). I do not have the proper test equipment to test dynamic range.
I can say that I have compared the 6600M side by side with my Elecraft K4D s/n 358 with their latest software and innmy suburban environment I could not find one radio able to receive better than the other. In my case the environmental noise is higher than the minimum discernible signal from either radio, meaning that both radios could receive better but limited by my environment. Most hams will find this to be true with many of the radios on Rob Sherwood’s list. Also real world band conditions when operating will also limit receive.
I do not have data to either dispute or back up your statements but as Mike pointed out, the Sherwood list is older and not tested with current software. I am not losing sleep over his dynamic range numbers.
73 Dave wo2x
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 837 Peripherals & Station Integration
- 146 Amateur Radio Interests
