Where can i find the format of the UDP message that SmartSDR logger send when i log a QSO
Hi Eric, The radio uses UDP for discovery and for audio/video (Vita-49 protocol). All else goes via the TCP/IP API.
Take a look at the API documents to get an idea of how it works.
There is also a C# FlexLib that you can use to access the API from a Windows DotNet environment. I recommend this if you are programming for Windows.
FlexLib: Class List (flexradio.com)
Node Red is also available. Dave, WO2X and Alan, WA9WUD have built some sophisticated flows for Node Red that you might be able to capitalize on. Sorry, I don't have a working link for Node Red at the moment, but someone here can point you in the right direction if you ask.
They are defined here in the wsjt-x source code and there are examples also on sourceforge.
I couldn't paste the link. But just put https at the beginning should get you there.
sourceforge.net/p/wsjt/wsjtx/ci/master/tree/UDPExamples/
Good Luck
Michael, AA5SH
Sorry wrong hpp file, I added the right one. Starts around like 117 or so.
Ok thanks I found that the payload in the UDP message is ADIF format. It threw me as it looks a bit like JSON but isn’t. Fortunately CloudLog expects ADIF wrapped in a JSON envelope.0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
