Smartlink Help Needed
Smartlink has always worked perfectly from my iPhone until yesterday. When I brought it up on the iPhone it did show a new release was installed a couple of weeks ago.
So local, on wifi, it all works fine. If I turn off Wifi and try to connect over the internet it doesn't work.
I have a 6600M and it shows Flex-6600 as an available choice as my available radio. The IP address is correct for my WAN address. I can go to the settings and "check Smartlink Status" and it shows all is good and I am signed in.
When I try to connect from my iPhone the available radio box goes away like it should but then it just sits on the previous screen that says I am not connected. After 20 or so seconds it gets a message that says "Smart Connect - No response from Smartlink Server".
Normally I would guess the server is down but it's probably something else.
Can anyone help me?
Harold
W5ZZT
i wrote Marcus and email and he got me working. In the extended setting I needed to turn use ipv6 on. It seems this has happened to me before when a new update comes out. That’s the only way I know it could have gotten turned off.
Harold
Just a guess...go and look under Settings on the SmartSDR iPhone app...at the top make sure Both is selected...
Both is selected and the radio shows up. I just unregistered the radio and registered it. I push the test button and it says I have a good connection.
The app on the phone says all is well. The available radio screen looks good. It just won't connect.
I was hoping for some help here before I open a ticket since it's a holiday.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
