It has an Internal Battery Flex 6400M
N4RAG
Hello Guys I have u Flex 6400M And I have the
Next Problem, I turn off the Radio Example
14.275, I go back and turn on the radio again
and When Raised Changes to 14,100, the Other that
does is When I Adjust the Radio Cal Frequency
Offset and then also change to 0, I would appreciate
Your help .
thanks for answering 73
OK, not exactly sure what your subject line has to do with the problem, but is sounds like you might have a problem with corruption in the saved 'persistence' object(s). I would try a hard reset of the radio. If the problem persists, I would then open a Help Desk ticket.
I believe there is a battery in the Flex, but I'm not sure it's the source of your problem.
- 112 SmartSDR+
- 944 Maestro
