Changing "Station: <computer name>" in SmartSDR
Brock
My first time configuration of my new-to-me 6400 was done with an old computer resurrected for the purpose. It got a fresh install of Windows 10, then the Flex software was installed.
The default name of the computer from the install seems to be in the bottom of the SmartSDR window... "Station: computer name". I changed the name of the computer in the Windows settings so that I could identify it separately from a laptop I may also use. However, that old name seems to be permanently burned into SmartSDR.
Is there a way to change it, or have it re-read this from the computer? Or perhaps I need to uninstall and re-install the Flex software?
Hi Brock, in SmartSDR you can click on the name and type over it to change it.
I have tried that and the computer name changes until I turn the radio off and the computer off. When I turn it back on the original name is back. How do I get it to change on a permanent basis?
Did you hit "Enter" when you had changed the name? If not, it changes back when you switch off SSDR.
THANK YOU! Hitting enter was so not obvious — but finally accepted the new station name (new PC so it was drivingme crazy)!
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
