FlexRadio.sys
I know this is an ancient FlexRadio, however, it just keeps going like the Energizer Battery. I recently setup Windows 11 and installed PowerSDR for my 5000A. Works great until I Stop or click Closer or shutdown windows. Then a BSOD occurs. I traced the cause to C:\Program Files\FlexRadio\FlexRadio.sys. What to do? :'(
  • Trucker
    Trucker Member ✭✭✭✭
    edited August 2022
    Open a command prompt in Administrator mode.
    At the prompt type:
    sfc /scannow
    Hit enter.
    Be sure to leave a space between sfc ( single space goes here) /scannow
    This will fix any corrupt files you may have. I had a similar issue with a used Dell pc that came with Windows 11 Pro pre-installed. Running System File Checker ( sfc) fixed the problem.
  • K4SKR
    K4SKR Member ✭✭
    RE: James. Thanks for your advice. I am familiar with sfc. I did run it after the last
    BSOD and several system files were found corrupt. I do not know if they correlate to the issue. I started PowerSDR and after an hour a BSOD occurred. I again traced the BSOD to flexradio.sys. I ran sfc and this time no problem found. PFN leading to BSOD caused by flexradio.sys may be a false flag.
  • Trucker
    Trucker Member ✭✭✭✭
    Have you ran LatencyMon alongside PowerSDR? Letting it run might give you more insight into what is happening. I had a heck of a time getting things stable with my 5000A and PowerSDR. Everything from issues using a PCI firewire card instead of PCIe firewire card to Turbo Boost in the BIOS ( I had to turn it off) . Also, Microsoft OneDrive would cause a BSOD when closing PowerSDR. I would get errors about t PowerSDR not having permission to save data in the OneDrive log file. I don't use off site storage so, I Uninstalled OneDrive and closing PowerSDR no longer crashes the pc.
    There are so many things that interact together and make things difficult to track down. Good luck.
  • K4SKR
    K4SKR Member ✭✭
    Hi James
    After many hours of testing, I can identify the cause of the PFN_LIST_CORRUPT which is FlexRadio.sys. sfc does not fix the problem because the BSOD continues to occur. Since the legacy product is no longer supported by Flex, I have chosen to sell the 5000A and move on to a 6000 series.
    Thanks for all your assistance and patience with me.
    K4SKR
  • Trucker
    Trucker Member ✭✭✭✭
    You will like the 6000 radios.
    I will offer one more suggestion. Go to KE9NS 's website and download his latest version of PowerSDR. Makes a backup of your settings. Then, uninstall the version of PowerSDR you currently have installed. Then install the new version from KE9NS . That should replace all the program files including Flexradio.sys.
    Hopefully, that will make a difference.
  • K4SKR
    K4SKR Member ✭✭
    Thanks. I am running the current version of KE9NS PowerSDR software. The installer does install FlexRadio.sys, however, it is the legacy driver that is not maintained by Darren.
  • Trucker
    Trucker Member ✭✭✭✭
    I forgot to mention I am also running Windows 11Pro. And after several initial problems, I have managed to get it to play nice with PowerSDR. I always pause Windows Update while I am running PowerSDR. Making sure the settings in the Flex Radio Firewire Utility are matched in PowerSDR really helped. I wish I could be of more help. But, I certainly understand your frustration.
