Flex 6600 Rack Mount Ears - Issue
I searched the forum and could not find an answer.
Received a set of the Flex 6600 rack ears. Before mounting them, I checked the spacing against my studio rack. As it turns out, the Flex rack ears spacing slots do not align with the standard US rack holes. Only one slot on each side aligns.
Has anyone seen this issue? Makes me ask the question, does Flex sell both imperial and metric spaced rack ears.
We have sold hundreds of those ears. They are all made from the same CNC machining process.
Any chance you are not looking at them the right way around?
Or, try sliding them up or down the rack and see if they line up.
I suppose that user error is always possible.
However, I checked both rack ear plates. Both sets of notches line up with each other. When I place the plates onto the rack in one orientation the slots are off just enough that the slots won't slip onto the screws. If I flip the plates over, only one of the holes aligns.
In my rack, I currently have a 1U recording interface, a 1U 2 channel microphone preamp, and a 2U reverb unit. Down at the bottom, I have the PGXL mounted with it's rack frame and it fits perfectly.
I pulled the reverb unit out to show how the plates sit exactly 3 U from the top.
I do have two 1/2U vents one above the preamp and one above the Lynx interface. These equal 1U. I pulled the top one out to move the different units up, but this made no difference.
I also placed 3U and 4U blanking plates below the preamp and both fit perfectly.
A bit stummped.
Hi Mike, I am guessing that you are off by 1/2 U. Can you move down 1/2?
The standard rack spec is EIA-310. Here is part of it:
This might be more clear:
I resolved the problem. The rack ears were punched just shy of 1/16" off center. This precluded the second **** from clearing and inserting into the rail(s).
I used a step drill bit on a drill press after marking the exact location to slightly enlarge the punched slot where the **** enters.
Problem resolved.
Been there done that... Swap sides.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
