No Power Out - CW 6600M
I get no power out from the radio. Everything looks normal, receive is good, MOX light comes on when I transmit, but no power out.
I've pushed the Tune button, no power
I've powered down, removed power, then reboot. No Change
I've done a factory reset, no change
The result is the same whether in Smart Contorl or Maestro mode.
Any magic I haven't tried?
Mike AD5A
  • Trucker
    Trucker Member ✭✭✭✭
    Do you have power out in other modes? On the right side is a dual knob for setting mic gain ( inner knob) and the outer knob is for setting power output. If this is the first time you have tried using CW you may have to set the output.
  • Mike Crownover
    Mike Crownover Member ✭✭
    Jim,
    I only do CW contesting with this radio. The power is set at 25 watts, but I've tried it at 100, still no output.
    Mike AD5A
  • David Decoons, wo2x
    Check your CW pitch. I’ve seen some people have it default to zero where both CW and Tune will not work.
  • Mike Crownover
    Dave,
    Thanks for the reply, but it was set at 600. I only operate CW with this rig, so all the settings have been in place for a long time.
    Mike AD5A
    Did you open a Help Desk ticket?
