No Power Out - CW 6600M
I get no power out from the radio. Everything looks normal, receive is good, MOX light comes on when I transmit, but no power out.
I've pushed the Tune button, no power
I've powered down, removed power, then reboot. No Change
I've done a factory reset, no change
The result is the same whether in Smart Contorl or Maestro mode.
Any magic I haven't tried?
Mike AD5A
Do you have power out in other modes? On the right side is a dual knob for setting mic gain ( inner knob) and the outer knob is for setting power output. If this is the first time you have tried using CW you may have to set the output.
Jim,
I only do CW contesting with this radio. The power is set at 25 watts, but I've tried it at 100, still no output.
Mike AD5A
Check your CW pitch. I’ve seen some people have it default to zero where both CW and Tune will not work.
Dave,
Thanks for the reply, but it was set at 600. I only operate CW with this rig, so all the settings have been in place for a long time.
Mike AD5A
Did you open a Help Desk ticket?
- 692 The Flea Market
- 119 Aurora
