Usb to Bluetooth dongle in flex6600 usb port
Question is the following
Is it possible to use a USB-Bluetooth adapter in the usb port of flex?
I would like to use a Bluetooth headset with microphone and, if possible, it seem2to a possible, clean, way
Tnx
Don
Ik2egl
No. Radio audio through though a USB to Bluetooth adapter into the back of the radio is not supported at this time.
you can use a USB to Bluetooth adapter into a PC and in SmartSDR select PC audio.
Hi Dave, thanks for clarification
I am looking for a way, without depending on smartsdr as I use maestro console only.
Maybe a Bluetooth microphone /headset adapter could be a solution?
You can connect a Bluetooth dongle to the back of a Maestro via the Line in and Line out connectors.
They do make them. You will need to do some research on finding on that handles both audio in and audio out.
However, be aware that BlueTooth will introduce additional audio latency. This is why Bluetooth is not present on a Maestro.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
