API Command For Multiplex PTT Client Selection
Alan
Alan Member ✭✭✭✭
I cannot find and need help for the API command to select the Local PTT Client.
Alan. WA9WUD
  • Eric-KE5DTO
    I think what you're looking for is in the SmartSDR v3.x Migration Guide. If not, let me know specifically what you're wanting to do and I'll see what I can do to help. You can also reach out via email to devhelp@flexradio.com for things like this. Best wishes and Happy Holidays.
    Thanks for posting this Eric, I really appreciate it. I think the API Wiki is getting a bit out of date, and this fills in the holes for the client commands.
  • Alan
    Alan Member ✭✭✭✭
    Erik
    I want to command the "local_ptt" to change. Same as shown in my original message, Smart SDR above, when you push the "enable" button.
    I found this in the Flex.Lib, but it does not work, when sent from my Non-GUI Client:
    I also tried Wire Shark from my Smart SDR GUI Client, but, no command is seen on WireShark, but I do see the GUI status change response:
    Alan. WA9WUD
    Hi Alan, did you bind your non-GUI client to a GUI client first? I am guessing that you did, but thought I would ask, just in case ...
    I wonder if you need to specify the client id or client handle in the command. Unfortunately, I can't experiment with it at the moment, or I would try some things out.
  • Alan
    Alan Member ✭✭✭✭
    Len
    Thanks for checking. I also had to check myself...and yes, the Non-GUI Client was bound to the GUI Client.
    Although....when you want to move the PTT client, using the GUI Client, you go to settings>multiplex, and if the GUI Client is not the PTT_Client, the "Enable" button is shown. Clicking on the button moves the PTT_Client to that GUI Client. Otherwise, if the GUI Client is already the PTT_Client, the "Enable" button is not shown. So....this indicates to me, that normal non-GUI binding to a GUI Client", may not be how this ("client set local ptt=0/1") is done.
    Alan
    Interesting... It may be that this command is only intended for a GUI client to execute. I wonder if (contrary to the documentation), use of a Client_Id in the command will have the desired effect. A long shot, I know, but maybe worth the time to try.
    If that is not it, Eric's offer to help may be the way to go.
  • Alan
    Alan Member ✭✭✭✭
    Erik and others.
    I want to add a button to my Node-Red dashboard, to change the "Local PTT Client".
    Both the Flex.lib and the Multiplex Transition guide point to using this command to change the Client PTT:
    "client set local_ptt=<0/1>"
    However, after I bind the Non-GUI Client to a GUI-Client (not sure this is necessary), when I send the above local_ptt, command from the Non-GUI Client, I get the following command response:
    "Invalid command for this client type (SSL vs TCP or GUI vs NON-GUI)"
    Also, strange, as I mentioned earlier, when I WireSharked the TCP packets, from my Smart SDR (GUI Client) to the Flex Server, when I pushed the "Enable Button" on the "settings>multiplex" panel, I do not see any TCP commands, but do see the TCP Flex Response? (See Screenshots, below, for the button I pushed and Wire Shark TCP follow).
    Help, there must be more to the "client set local_ptt=..." command then what is apparent??
    Alan. WA9WUD
    Wire Shark TCP Follow:
  • K6HN
    K6HN Member ✭✭
    Did anyone ever figure this out? I am looking for the command also.
  • David Decoons, wo2x
    Hi Gary
    The command A,an posted above needs to be sent from the GUI client. Node Red for example is bound to a client and cannot send the command to the radio. It needs to originate from the Actual client (Maestro, PC running SmartSDR, etc).
  • K6HN
    K6HN Member ✭✭
    Hi Dave,
    Thanks for the explanation. That makes sense, though unfortunate.
    Gary
    Maybe someone from Flex can chime in if there is either a way or maybe in a future API update.
    I guess the reason is to ensure no one can “hijack” your client. Just a guess.
