interaction between DAX channels on 2 multiflex computers
N4AB
I have a desktop and laptop computer and I am getting an interaction between DAX channels on the 2 multiflex computers. changing DAX channels on either computer sometimes sets the other computer to "DAX None" Are there any preliminary instructions on how to operate and setup DAX and/or Multiflex. I haven't found much on the community about setup or operating the video on the Flex website is not very helpful about it. Kind of like shooting in the dark right now.
Al, N4AB
Al, N4AB
At the top of the DAX panel there is the "Station" Pull Down.
Are you on the correct station for each computer?
Hope this helps
Yes each DAX panel is set to the right station, sure would be nice to get some setup info soon.
TNX Al, N4AB0 -
This sounds very similar to the problem I've just encountered and posted about. Was a cure offered? 73, Phil VK4KW0
Can you start a new thread on this and describe what you are seeing? A video is very helpful. Don't forget to mention the radio you are using and the software versions.
There discussion is over 3 years old and many code changes later.
- 391 Community Topics
- 665 The Flea Market
- 168 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
