microphones for 6400 M
2»
  • Member ✭✭
    [{"insert":"I bought the Flex ACC-8P-TRS adapter right from Flex, and I see a problem with the way it is wired. I checked the pin out before plugging the adapter in and found the the TIP of the TRS (3.5mm) plug is going to pin 7 of the 8 pin Foster plug, and RING of the TRS (3.5mm) plug is going to pin 8 of the Foster plug. That does not seem right to me. The Yaesu 8 pin Foster plug is wired with the MIC+ on pin 8 and MIC- on pin 7. In other words the White wire of the Yaesu mic. is on pin 8 and the bread or shield is on pin 7. What is a mother to do??? \n"}]
  • Member, Super Elmer Moderator
    @n4frl email me off list. I have some documentation for the 8 band EQ and EQ Plus with Flex gear that may be of help.
    You are adjusting the MIC In wrong on the 8 band EQ. Do not use the noise gate LED to adjust Mic In on bottom. The document I have explains it.
  • Member ✭✭
    @radioshopbob Should I not be using the Flex ACC-8P-TRS since it is wired incorrectly. I use different mic but mainly the Heil 781. Can you tell where and which cable to buy?
    Thank you
  • Member ✭✭
    @wo2x David I can't seem to figure out how to find your email. I also cannot seem to get the confirmation email to confirm my membership. I did find an error in my profile where i had entered my email wrong so I corrected it but never received the confirmation email
    N4FRL
    Ferrell
    Go to http://www.QRZ.com
    Put in my call (you need to sign in the site, basic membership is free. You must be signed in. Then after signing in and entering my call you will see show email.
    Or easy way my call AT ARRL DOT net
  • Member ✭✭
    @radioshopbob I have the Flex ACC-8P-TRS also. I use about mic wired for yaesu. Anyway is there something I should change or just not use the adapter or buy another type of adapter
