6400M transmit hang up
W2VTV
in Contesting
Morning to the group, I'm setting up for the NAQP RTTY contest tomorrow. I've got the Flex working with N1MM and MMtty without a problem. As I test the transmit, the M doesn't drop transmit, I have to tap the MOX button once or twice to have it drop out.
What am I doing wrong? Using SmartControl, so that I can use the desktop and mouse to select signals. Your help appreciated, John, W2VTV
Usually, this happens when the APP doesn't send an unKey command.
What method are you using to key and unkey the radio? RS232 or CAT?
That would be the first place I would look.
Hi Mike, CAT0
Mike I got it, I added a separate PTT port for MMTTY . works as it should. thanks for your time. 73 John0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
