6400M transmit hang up
W2VTV
W2VTV Member ✭✭
Morning to the group, I'm setting up for the NAQP RTTY contest tomorrow. I've got the Flex working with N1MM and MMtty without a problem. As I test the transmit, the M doesn't drop transmit, I have to tap the MOX button once or twice to have it drop out.
What am I doing wrong? Using SmartControl, so that I can use the desktop and mouse to select signals. Your help appreciated, John, W2VTV
    Usually, this happens when the APP doesn't send an unKey command.
    What method are you using to key and unkey the radio? RS232 or CAT?
    That would be the first place I would look.
  • W2VTV
    W2VTV Member ✭✭
    Hi Mike, CAT
  • W2VTV
    W2VTV Member ✭✭
    Mike I got it, I added a separate PTT port for MMTTY . works as it should. thanks for your time. 73 John
