3.3.29.7670 observation with VOX
I'm loaded 3.3.29 and first observation was band hopping and vox had to be reactivated to work as in 3.2.29 it carried forward on the new slice. Now it's not staying activated. All it takes is a tap on the VOX to off then back on and then its works in the new slice.
Anyone seeing this?
Jim
WU5E
I have also found this fault with the VOX operation on my new 6600. Now that I see others have this problem I can stop trying to find the fault in my operating proceedures.
Me too.
yes, I reported it here - https://community.flexradio.com/discussion/8026495/bugs-critical-for-me
After installing FW 3.3.32 I to have vox dropouts and I make sure to turn Dax off before enabling Vox . This is not a miner problem that happens occasionally . This happens on every 2 or 3 transmits, the op I'm talking with will say, you dropped out after this . I have the same issue on my 6600 and 6500 . Vox has not been a problem with previous versions. Is Flex working on this ?
Ed N5DG
- 391 Community Topics
- 665 The Flea Market
- 168 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
