Can the TGXL change antennas without a CAT Connection from non-flex radio?
Apparently the tuner will use RF sensing to find a tuning solution. Without a CAT connection, can the tuner change antennas? It would seem that with this configuration, "no." If so is there any workaround?
I use the single CAT connection for rig control / logging. Any solutions to share the CAT connection with the tuner?
Dave
N4CQ
Best Answers
My understanding is you will need a ptt from radio to TGXL in order to activate the rf sense in the tuner. Start at section 6.3.1.3 in the TGXL manual. You will need at least a 20ms delay from transmitter to tuner otherwise you will need to key the tuner first and then key up the radio which is described in the manual.
Don - kx9q
Don,
Thanks for the response. I got the tuner setup and operating just as you say. I actually asked how to change antennas. I found out that you can click on the ANTENNA 1, 2, OR 3 block in the TGXL software to change antennas. It works well. 73
Dave
N4CQ0 -
Thanks for the response, Don. I got the tuner setup and operating just as you say. I actually asked how to change antennas. I found out that you can click on the ANTENNA 1, 2, OR 3 block in the TGXL software to change antennas. It works well.
Dave
N4CQ0 -
Hi Dave
Sorry, I didn't read far enough in your original post. Yes, it is very easy changing the antenna port using the TGXL software. I have two antennas - beam and vertical. I use the third antenna port for the dummy load.
Don - kx9q
It should remember last port used for a band.
See my other post on here about the used with a K3 and TG XL. Third party software such as Eterlogic’s Virtual Serial Port Emulator can create a bridge between the radio CAT port on PC, a USB to serial cable to tuner, and a virtual port to be shared between all software (logging, WSJT-X, etc).
Contact me direct if you would like more info.
- 311 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 9K Radios and Accessories
- 110 FLEX-8000 Signature Series
- 887 Maestro
- 49 FlexControl
- 842 Genius Products
- 434 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 687 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 915 Third-Party Software
