How do I get TX audio from N1MM using MMVARI
normancyyj
When I use N1MM with MMTY all is good. When I switch the interface from MMTTY to MMVARI RX is good.When I TX the audio shows in the monitor screen, the Flex goes into the TX mode but no audio comes thru. I need some help here.
Possibly you do not have the correct audio path set for transmission:
Thank you for your response Erik. I just found the sound card button. I didn't notice it there. All is well and working just fine now..
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
