How do I get TX audio from N1MM using MMVARI
When I use N1MM with MMTY all is good. When I switch the interface from MMTTY to MMVARI RX is good.When I TX the audio shows in the monitor screen, the Flex goes into the TX mode but no audio comes thru. I need some help here.
  • Erik Carling EI4KF
    Possibly you do not have the correct audio path set for transmission:
  • normancyyj
    normancyyj Member ✭✭
    Thank you for your response Erik. I just found the sound card button. I didn't notice it there. All is well and working just fine now..
