Configure Telnet Connection in FRStack
I have version 3.1.35.65 installed and I do not see where to enter Telnet info for the spot function. Under View -> Options -> there is no "Spot" selection. I see only other spot related entries.
What am I missing?
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited July 2022
    View/Options/Spots
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hi Larry,
    Thanks for your reply. Attached is what I see.
  • Geoff AB6BT
    OK, I think I see what happened.
    I had not uninstalled an older version 2 when I installed the version 3. That appears to have left me with the version 2 menu configuration.
    I uninstalled v2 and tried the v3 install again.
    Now I see the new tabs under the options selection.
    Thanks!
  • Larry _ NY8T
    Thats strange, your using the same version i am, your missing a row of tabs in options.
  • Geoff AB6BT
    See my previous response.
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    FRStack V2 and V3 can be installed at the same time. They different install folders and have two different ICON names.
    FRStack ICON is V2 and FRStack3 ICON is V3.
  • Geoff AB6BT
    Thanks for you reply.
    Well, perhaps it was my error. I could have sworn that I closed V2 prior to opening V3.
    I had a shortcut on the taskbar for V2. I believe I closed V2 and then opened V3 from the Program Files V3 folder location.
    It's water under the bridge now.
